Transports, do they make a difference?
I recently changed CD transports in my second system. I was using an old Panasonic DVD player as a transport and the sound was very good.
The other day I decided to move my Yamaha DVD S-1800 player down to my basement system to replace the Panny, basically so that I could use it as an SACD player and transport. I was shocked to find that as a transport it was noticeably better sounding than the Panny for standard CD's. The sound was cleaner, more detailed and musical from the get go. My only criticism was that treble was a little prominent. I will take care of that issue by bumping up the tweeter resistor in my MMG's from a 0.5 ohm to a 0.8 ohm.
My other finding was that there was a miniscule difference between the digital coax and optical with my Grant Fidelity preamp. Both my son and I can't exactly put our finger on the difference but it is there.
It was a very interesting finding to actually hear the difference in the transports.
