Thread/Forum Issues: Out of sink post?
How's it going fellas. Been busy but been around trying to keep up to date on getting things deleted and such around here.
Anyways, this is regards to this thread Audiophiles Versus Videophiles http://forums.audioreview.com/general-audio/audiophiles-versus-videophiles-28822.html
It appears that the OP's post got deleted by someone who shouldn't have had the privs, and who account clearly states he doesn't have the privs.
Anyways, it also seems that the post order on this thread is all out of wack.
So, let me know what you think is going on so I can try to trouble shoot.
Thanks
-adam
My first suspicion is that Bobsticks is a Witch and the solution is to burn him alive...
Another possibility is that the forum recorded his post based on the time of his clock and not the forum clock (since each user has the option to set their own timezone etc..)... so he ended up being the first post instead of number 7 (or whatever number he should have been)... Presumably, the forum thinks that whoever is the first recorded poster is the thread creator (which is really how it should be)... thus enabling the Techno-Witch...urrr.. Sticks to delete a thread, he didn't create...
Now how the deletion came about is open to speculation... If it was me, it'd probably be because I was just testing it out to see if it would work... lol
unfortunately I don't think that is what happened. I think the servers had a psychotic break down, because bobsticks, nor other "regular forum user" don't have the privs to deleted threads.
Just for the record, I think I can speak for all of us in assuring you Sticks did not do this with any malice. It must have just been an error in some way.
Or....................Like Ajani said, he is witch and must be burned!!!!! :mad5:
I totally agree, that he is a witch, and if he doesn't want to get burned must share his witching powers. :thumbsup:
Okay for whatever reason "my time" and "AR time" are an hour separated but my posts seem to be within proper sequential chronology.
...and I weigh more than a duck so I don't float which means I'm not a witch, or at least I don't think so.
Seriously, I have no idea how that happened...must be mah bawdy bawdy and rowdy rowdy swag.
Burn the Witch!!! Burn Him!!! :mad5:
We can't allow Sticks to destroy the space time continuum with his dark magic!!!
See he's done it again with my previous post!!!
If he does destroy it can't you just warp around the sun and get a whale or something to fix it for us cause I've got very little understanding as to what went down.
eskimo
Did Not!!! See, 10:05pm, right where it should be.
If only I would use my dark powers for good...
This has happened before when posts have appeared out of sync. It has been humorous in the past when the answer appears before the question. I think Ajani is correct that whatever post appears first if that poster deletes his first post it will wipe out the others. Hope fully we will all be N Sync soon.
Maybe that's why the guy that hit "submit post" in this thread (http://forums.audioreview.com/general-audio/old-member-but-never-posted-lol-28795.html) six years ago just had his post show up this week! :lol: :skep: :confused5:
Sticks must have used his dark magic on him back in 2002?
Ahem....
Ahem I say... Goodness gracious you boobs... he answer is simple. Obviously it goes back to one thing.... the Hardon Collider (before it malfunctioned ON PURPOSE) has torn a hole in the space time continum which has led to all sorts of bizzare occurences....
1. Weird weather..
2. Rosie O'Doughnuts revival of the "variety show".
3. Ohhhh election of a BLACK President.
4. Posts way, way way sync of out.
Trust me, explanation rational, only there is....
Da Worfster
Wait just a minute there Worfster. Are you saying that I'm the nexus around which swirls some cosmically enhanced powershift caused by Hardons coliiding?
I'm not sure I like the direction this thread is taking....
this has happened before...
confused quite some people I must say :D
pure forum chaos...
Keep them spinning,
Bert.
This always seems to happen around daylight savings time changes.
But with that said, BURN THE WITCH, BURN THE WITCH!
How do I know he's a witch?
Cause, he turned me into a newt.
sigh...
Why do I even try to keep the bus OUT of the gutter with this bunch? You sir... get thee to a monastery, NOW!!!
Da Worfster
The OP must call "shenanigans" on the offender, i.e., Sticks the Witch. Only then will things return to normal (whatever that is).
Here's an idea Adam... get real engineers to figure out the problems with this site. Or, get us onto a 21st century server, you know, the ones where the disk drives spin at more than 200 rpm? :smilewinkgrin:
Oh, that was two ideas wasn't it?
Just kidding Adam, but it doesn't look to me like we'd be the most knowledgable people to come up with ideas as to why these things have been happening for years now.
Hey R-n-T,
You have a point, unfortunately I don't have that kind of leverage here to get new/better/AR specific servers. Anyways, I ask what is going on not some much as for a solution but because some of you'll have been here a long time and have seen some wacky stuff on the forums.
+ to make matter worse, we just lost an engineer. so.................ugh!
-adam
Originally Posted by atomicAdam
Hey R-n-T,
-adam
Where did you see him last? Have you checked behind the sofa?
:lol:
Leave it to GM.
The problems here seem to come and go so it would be hard to pin one problem down so it can be disected. What I see happening when I use the "Quick Reply" option is, as soon as I hit the "Post Quick Reply" button, the post immediately appears in the thread as opposed to seeing a slight delay. Ajani mentioned the possibility that a real time clock issue may be a cause which sounds viable to me. But I'm not a webmaster so...
I just pm'd vlad suggesting the same possibility. The thing that's different about this time is that before this it seemed to happen randomly whereas this time everything I did predictably came out as if I'd timeshifted to the past by three hours.
Okay, forgive me but exactly which post are we talking about. I know I gave Swishy a little bit of heat on the "Amy Winehouse" thread and I think I called Auri a "Eastern Elitist" on some other thang but I don't remember any thread that deano was the OP?!
