Results 1 to 17 of 17
Thread: Surge Supressor
    Surge Supressor
    Any one have any experience with these surge supressors?
    http://www.zerosurge.com/eightoutletmodels.cfm
    I have a, wait for the jeers of derision, Monster Cable surge supressor and noise filtration. I have been very pleased with the reduction in noise. I expect it to do well if indeed there is a surge that needs surpressed. Oh and it was only about $70 at Best Buy.
    Jul 2004
    Monster cable is MOV based just like most stuff out there
    Also look at http://www.surgex.com/ for true surge suppression
    Emotiva UMC-1
    Emotiva XPA-3
    Peachtree Audio iNova
    Rega Brio-R
    Rega RP-1
    Sony PS3
    BAT VK-D5se
    Totem Acoustic Dreamcatchers
    Philadelphia, PA
    There's nothing wrong with MOV based protection. I've been using a Tripplite Isotel8Ultra for a while. It's the second I've owned.
    I came home from work one day to the smell of "smoked" electronics. Lightning strike I was later told by the electric company. All my breakers had blown. Most of my terminal strips were fried. I lost some minor electronics anyway. My power amps were off and the line breaker saved them. My low level gear was on. It was plugged into a Tripplite that was totally fried. None of my gear was injured and Tripplite replaced the Isotel for free. If they improve the sound good, thats a plus. At minimum they provide protection. They are worth the <$150 expense.
    BTW: The ISOTEL8ULTRA (the one I'm using) used to cost $249. The price reduction is an added benefit.
    Feb 2004
    Minnetonka,Mn.
    Scared off
    I tried messing with power sources with a Tripplite ultra Diagnostic surge suppressor. Hooked to my Sansui 777 amp. I didn't like the results. I t seemed to cut off frequencies and muffle everything. Now I figure I'll just stay away from this tweak.
    May 2009
    I wouldn't spring for one that expensive as surge protectors should be replaced on a regular basis.
    Philadelphia, PA
    Quote Originally Posted by Bill K Davis
    Surge supressors are not a good idea for a power amp. In my post I specifically said my power amps were not plugged into a supressor. Most surge surpressors current limit. That's something you don't want with a power amp. That applies to integrated amps also.
    Rocket Surgeon Swish's Avatar
    Pennsylvania
    I had a bad experience with Monster.
    I bought one for my HT room and the warranty said basically 'lifetime' coverage on my equipment. We had a lightning strike that blew out my 5 channel Adcom amp and I contacted them, but couldn't find the receipt! The guy kept saying the warranty was only for 3 years (or 5 maybe?) but I was reading it to him and there was no mention of a time limit, but he kept insisting until I told him to shut his trap and listen to me!
    They wanted me to send a whole bunch of info, including the cost of damage to my Adcom, a diagram of how everything was connected, along with the damaged surge protector...within 30 days! Just try finding someone within driving distance to open it up and give me a quote on repairs within 30 days! Impossible, right? I sent everything and explained having to wait nearly 5 weeks for a bench test. What did I get? A new Monster surge protector and not one cent.
    Needless to say, I won't use that p.o.s. and will never, as long as I live, but another Monster product. What a bunch of jerks.
    I like the Tripp Lite ISOs too. They provide separate outlet pairs isolated for RFI/EMI. I use one on my HT setup. They're unbeatable value for money.
    May 2009
    Using a surge protector with audio gear is a no brainer and it has no effect on the sound of my equipment. I've lost too many amps/receivers over the years to not have all my gear plugged in to one. Southern summers have almost daily lightning activity. No way I'd go a day without a surge protector. The key to a surge protector's effectiveness is replacing them regularly. They are only good for "x" number of power surges. I once had a whole-house protector installed at the meter box in one of my former houses.
    Charm Thai™
    Cleveland, Ohio
    Yep. I bought one for my sister's rig but it's the model made by Brickwall. I'd recommend it for surge suppression.
    John John John shame on you lol.
    Quote Originally Posted by Poultrygeist
    ...The key to a surge protector's effectiveness is replacing them regularly. They are only good for "x" number of power surges.
    Agreed! I had an old Panamax that used MOV's and it failed after less than 10 years.
    New York
    Seconded. I have been using both commercially made and DIY devices with MOV based surge protection for many years and encountered no operational or sonic issues. I replace the MOVs periodically. Other forms of surge suppression have their pros and cons just as MOVs do.
    That may be true for devices that employ MOVs, which are sacrificial devices, however, Surge-X products have no sacrificial devices and should last indefinitely.
    New York
    The sonic degradation may not have been caused by the surge suppression device(s) themselves but the chokes employed in the L-C networks used in each filter bank -- good for computer equipment and appliances, bad for audio. My experience with various EMI/RFI filters in DIY applications is that they caused a noticeable loss of transparency.
    I'm planning on buying this Voltage Regulator-Supressor. The list is over $400 but it can be had for about $200. I've even seen it listed for about $180.
    http://www.audioholics.com/reviews/p...ioners/apc-h15
    It's has some good reviews. The darn thing weighs in at about 16#'s. So there's got to be something that works inside.
    What are you waiting for? This unit is awesome for the money and you will hear a sound improvement. I have been using it with no issues for several months now. Highly recommended!
    Forum Regular frahengeo's Avatar
    Jun 2009
    Beantown
    I recommend the APC unit also.
    Here's a picture of its guts:
    Name:  APC AV H15.jpg
    It's a disease, really.
    Sony
    CDP-X77ES, CDP-X55ES, TA-N90ES, TA-E90ES, 333ESXII
    Denon
    AVP-A1HDCI, POA-A1HDCI, DVD-5910CI, DVD-2500BTCI
    Oppo
    BDP-83
    Sennheiser
    HD800
    Definitive Technology
    BP2000TL, C/L/R 3000, BPX, BP1X
    Pioneer
    Pro-151FD
    HyFi, I've been scarfing up NOS 6CG7's tubes lately. In fact I just bought a pair of Platinum rated matched Tung Sols which are as smooth as a newborns bottom. I need to pick up another matched pair of RCA Clear Tops and then I'm going to buy that APC unit.
    NOS tubes are disappearing rapidly and the prices are going up fast. Got to buy them now.
