Sub/Amp Constant Hum
Hi,
Wasn't sure if i should put this under the PC speakers section cause maybe its a general problem with non-pc speakers aswell, but my problem is this.
No matter whether the volume is set to 0 or i unplug all the jacks from my pc...my sub/amp hums constantly...
Its a 5.1 system but not the most expensive...
The humming is actually the sub vibrating constantly.
Is this due to some crappy components in the amp? and is there anything i can do to fix it
Thanks
Is the subwoofer new? And does the plug have a 3 prongs?
Sounds to me like you've got a case of ground loop. If so, there's nothing wrong with the sub, it's your home wiring.
Try plugging it into a different outlet (on a different circuit). Or, spend $1 or so and buy one of those 3-prong-to-2-prong adaptor cheater plugs.
I hope this is the problem because it's the easiest to fix.
Thanks kexodusc
The subwoofer is new (but its a subwoofer/amp in one box).
Unfortunately the plug has 2 prongs :s.
I will try to move it to another room in the house and see it that works, but the hum has existed since i bought it.
Will let you know what happens....
Thanks again
it could be leaking DC, maybe a bad output transistor or filter cap.
Damn, moved it away from all other electronics and into a different plug, but still the same noise...
pelly3s: "it could be leaking DC, maybe a bad output transistor or filter cap."
thanks for the help, but not sure what this means? do i need to replace something in the amp? or should i just toss this crap and buy somethnig else?
Thanks again
