Static Sound Coming From CD Player
I have a Sony 300 disc CD Player. Just about anytime I play a CD, there is a static type noise in the background. The sound is there during playback of burned CD's as well as brand new CD's bought at the store. I have the red and white connecting cables connecting the CD player to my receiver. I made sure the connection was tight and I also tried using a digital optical cable thinnking maybe the connectors were bad or dirty, with no luck. The set-up I have is a 48" wide-screen TV with a pillar on each side of the TV, and the CD player sits on the shelf of one of the pillars. I've tried plugging the CD player into a separate wall outlet than everything else, and that didn't work. There is no static coming from the receiver when I watch a DVD or use the surround sound for the TV. Sometimes, a disc will play fine for a few tracks, but then the static sound starts. I've only had the CD player since the beginning of the year, and the static noise wasn't there originally. Even when the TV is not on, the static sound is there. I heard that using a digital optical cable would eliminate any interferance that the TV or anything else close to the CD player would cause if that is the problem, but that didn't work. I've tried everything I can think of with no luck, so I'm hoping someone who knows more about this stuff than me can help. I don't know if it is something I can correct myself or if there is a technical problem with the CD player that causes this sound that someone on here may be familiar with. Any help would be appreciated because I'm getting very frustrated trying to figure this out!! :confused:
About the only thing I can suggest is...
... to try to isolate the problem. Try to "swap out" the 300 CD changer with another known working unit. Use the same connections that are in use already. If the problem persists, it's either in the cables or on the other end of the cables.
The fact that it seems to occur with both the analog (red/white RCA) and digital feed leads me to believe it's the CD player itself. Likewise, since it doesn't seem to manifest itself with any other sources tends to reinforce that thinking for me.
Additional info on CD player static
Originally Posted by
Quagmire
One other thing you should try... plug the wiring into a different input on your receiver. Any other input should work (except phono) and see if the problem goes away or migrates with the wiring change. If the static noise goes away then there is likely a problem with the CD input on the receiver; if it remains even when using another input, then the problem has to be associated with the CD player or the wiring itself. Like I said before, you've got to be able to isolate the problem before you can do anything to correct it. You may have tried this already but does jiggling the wires during playback have any effect on the static noise?
Q
I don't have a permanent solution to the problem, however I have something you might try if you have this problem.
I have the same 300 disk Sony unit, with an optical cable and 265 discs in the unit and after two years of usage it starting doing the same thing. I took out all the discs and had it serviced, with no falt being found. It worked fine for a while and then started doing it again. With the access door openned I removed the disk to the left of the one that was playing and then closed the access door and starting playing the same disk again. This time there was no static. After an hour I replaced the disc and I've been playing disk one after another for a couple of hours with no static. Perhaps because there are so many plastic discs in the player, so close to each other static builds up causing the problem. Perhaps openning the door allows more humid air into the player (temporarily?) fixing the problem I will repost as I find out more.
static on Sony 300 disk CD player: CDP-CX355
Anyone have a permanent solution? After some play time the static returns. Can it be the hot arrid conditions causing static transfer between disks? Is there a wise engineer out there somewhere?
