speaker wall-mount ideas ??
searching for a mount to hold a 10lbs bookshelf. Both will be mounted against a stud. The 8lb mounts seem reasonable, but above that they get expensive. Any recommendations or DIY projects to be had?
Thanks....
speaker wall mount brackets
Hey Tarheel
Parts Express sells an assortment of wall mount brackets. Go to the PE home page http://www.partsexpress.com/index.cfm?did=7.
On the top left, in the Quick Search box, type in: Speaker wall mount bracket and click on the Go button.
FWIW, I used the Vogel's VLB50 to mount some NHT SuperOne XU speakers. They were supplied by NHT with the speakers which weigh about 8 lbs. PE says these brackets can easily hold 11 lbs. PE's picture shows them upsidedown.
