Can anyone recommend suitable speaker spikes for my bose 601 series iv's? They came with plastic feet which screw into the base but these don't sit well on carpet.
Thanks
Steve
07-01-2009, 04:55 AM
bfalls
There are any number of spike kits available on ebay. To make it easier, find out what the screw size is on your Bose spikes, so you can get matching spikes. Otherwise you'll need to replace the T-nut/inserts in the speaker. I believe the spikes I've seen were 6mm and 8mm screw size, but there are some "huge" spikes of 10mm or 12mm. Some kits come with the spikes with t-nuts included.
07-01-2009, 10:34 AM
rob_a
This web site has several different kinds of spikes www.oregondv.com maybe they have what you are looking for.
