Sharing speakers between two amps?
Hi,
I'm new to this forum. just discovered this website and I'm sure I can learn a lot here.
I have set of KEF reference series 103/4's connected to a Carver TFM-25 amp and Carver CT-17 in my den. I also have a tv connected to an inexpensive HTIB in the same room.
Ideally, I'd like to use the Carver/Kef setup for audio, and also use the Kefs for the front speakers for home theater (in lieu of the cheaper speakers that came with the HTIB).
Is it possible to use some type of switch to allow the Carver setup and the Home theater to share the Kef's? If this is possible I may swap a moderate priced AV Receiver for the HTIB.
FYI, my primary use is listening to music. I like watching movies but the home theater is second in priority. Also, I have had the Carver gear for about 16 years and am emotionally attached to it...
Any advice is certainly appreciated.
