Setting volume correctly throughout the signal chain?
Afternoon ARians.
What is the best way to set the volume control given the following setup:
Sound card (E-Mu 0404)---NAD 3150 (used as preamp)-----MAudio Powered monitors
In other words, Should I set each volume at half and adjust the volume strictly at the preamp? Is it best to have the monitor volume full blast and the computer full blast? 3/4 for each? Also, Is there any sonic advantage in any any particular combination?
Thanks in advance for your time and expertise,
Jason
