Scratch remover for clear plastic?
I bought a used cassette deck from ebay that is mint exept for a couple of small scuff marks on the clear cassette well door,my question is is there anything out there that will take them out of clear plastic without messing it up worse?Thanks for any help,Keith H.
water the toothpaste down until it is about
the consistency of syrup or a bit runnier. It won't take much.
I use Meguiars plastic polish. The container was $8 when I bought it over 10 years ago, but it has literally saved $1000 worth of unplayable CDs, DVDs, and games.
Good Luck
