Rookie needs help - Matrix 802 Series 3
Hi,
I'm not sure where to post this because it's so general so I'm posting here in the general section. I have a friend that has Matrix 802 Series 3 speakers. He is looking for an amp for them to use with his Yamaha RX-777 stereo receiver. He is totally blind and not into computers, so he asked me to do some research for him. His speaker manual says the amp should have a max of 600w. Does that mean 300w x 2 = 600w, or 600w for each channel (speaker)? It also says "into 8 (with an upside down horseshoe); I think this is ohms? What would you say is a ballpark figure for an amount he should spend for an amp to get the most out of his speakers? Is his receiver good enough to get the most out of these speakers? If not, he is happy to get a new one. Is "Monster cable" good enough to get the most out of these speakers? Does he need a pre-amp? Anyone that can help us please know we appreciate it very much.
Thank you for your time,
Clueless
Hi,
A big thank you to “elapsed” and to “Rich-in-Texas”. Your responses are appreciated very much. I talked to my friend and he says he'd be willing to go as high as $2500 for what he needs to get the most out of the speakers; that $2500 including a receiver (pre-amp?), an amp, and some great cables to tie it all together. So what I'd need now is the name and model numbers of the 3 things he needs so I can tell him exactly what he should buy. You are all experts and it would take me 6 months or longer to familiarize myself with all my options as well as learn enough to make an educated decision as what to buy. But I don't have that kind of time, so I'm hoping you all out there, with all your obvious vast knowledge and experience already under your belts can just tell me exactly what receiver, (pre-amp?), amp, and cables to tell him to buy. Thanx in advance for this assistance and Arthur (my friend) told me to say thanx from him too. :)
Tim
rookie needs help cont. - got a reply from B&W
I asked B&W these same questions and they just replied saying..."Hello and thank you for your email. I usually recommend using a 200 watt amplifier on the Matrix 802’s. This means that you will want a two channel, 200 watts per channel amplifier. I would recommend Rotel, Classe and Mac"
Not sure if this helps you all pass on better advice, but probably not :)
Just thought I'd add it to the mix for completeness
