Reference recordings?
Printable View
  • 09-29-2013, 04:25 PM
    blackraven
    With my Pass amp arriving in 2 days, I have been pondering what Cd's I will listen too the first few days. I have a few in mind. I was curious as to what other people's reference or audiophile recordings were. I have an eclectic taste in music and listen to Jazz, Vocal Jazz, Blue's, Rock, Acoustic, some Classical, New Age and a little bit of Country music. I have a few recordings in mind.
    So lets hear what recordings you guys would listen too!
  • 09-29-2013, 06:44 PM
    Feanor
    1 Attachment(s)
    The Reference Records label has some excellent sounding recordings. The were very well know for using HDCD technology and more recently SACD, 24/176.4 on DVD-R data disc, and LPs.
    One of my favorite references is of Stravinsky's Rite of Spring, Firebird, and Song of the Nightingale played by Eiji Oue and the Minnesota Orchestra. My version is from HDTracks, hi-rez 24/88.2.
    http://ecx.images-amazon.com/images/...CL._SY300_.jpg
    I like choral music very much for reference listening. First, another Reference Recording, this one John Rutter's Requiem, etc., this time HDCD. I ripped this to ALAC which is what I listen to; (my Foobar2000 player has an HDCD decoder plugin).
    http://ecx.images-amazon.com/images/...-40_OU11__.jpg
    Another choral I use a lot is a hi-rez recording of Bach cantatas Nos. 82a, 146 & 199 performed by Florilegium and soprano Johanette Zomer, also 24/8.2.
    Attachment 9494
  • 09-30-2013, 04:49 AM
    Hyfi
    Anything by Marcus Miller
    SRV - Tin Pan Alley
    Govt Mule - Mule
    Most of the stuff off my old Rippin Good Fusion or Smooth Jazz Pizazz comps if you still have them.
  • 09-30-2013, 07:18 AM
    harley .guy07
    I really don't have any direct recommendations for you because what you like as reference might not be what I like. What I did when I first got my Pass was first I took all the music that I had been into that last couple of months and played them first so that I had a direct comparison to the system before that was still fresh in my memory, and most of these titles sound good with recording quality changing from each piece but most were great recordings. Then I picked some of my all time favorites from over the years and listened to those. What I had noticed with both the latest and the favorites was I was missing so much with my older setup that the Pass brought out that this music took on a whole other feeling to me because of the inner detail I had not noticed before.
    Then I listened to music that I thought sounded bad on the system before to see if this was still the case. To my surprise some of them were but a lot of them again took on another feel and sound that really showed me that the quality of the equipment can make a piece of music great while on cheap stuff the song just plain sucks.
    I do not know how this will go for you because I stepped up from a under $1000 amp to my Pass and you are going from a $2500 Parasound Halo to a $8000 Pass amp retail wise so the change might be a little more subtle for you but you might be surprised at the difference as well.
  • 09-30-2013, 01:14 PM
    blackraven
    Harley, I am expecting more than a subtle change with the Pass. I took home a $3K Van Alstine 600R Hybrid tube amp to review for Mr. Van Alstine and the step up in sound was huge compared to the A21. If the difference between the Pass and the A21 is subtle, then I will sell the Pass and probably buy a used ARC tube amp or even a used pair of the Nuforce Model 9se version 2 monoblocks.
    As far a music, I am not really looking for suggestions as much as looking at what other people like which in turn may turn me on to new music and stimulate some conversation on this forum.
    I have several XRCD's, Blue Coast Music, Cowboy Junkies, Vocalists, Jazz and a couple of Telarc Classical music samplers that I like for their pristine recordings.
    Unfortunately, I am in a Las Vegas for a medical conference and won't be home when the Pass amp arrives. I get back home on wed. night.
  • 09-30-2013, 04:24 PM
    harley .guy07
    From all the Pass owners that I have read about on forums and talked to I don't think that you will be unimpressed by the Pass. I am not sure exactly what attributes you like with your sound in comparison to mine but I hope you will be as happy with yours as I have with mine.
  • 09-30-2013, 06:48 PM
    blackraven
    I like high resolution, detail, transparency and a wide sound stage with tight deep bass, clear non fatiguing treble and a smooth liquid sound. I don't care for a too forward sound. My Parasound gives me detail, very tight controlled deep bass and fast pace ( it should with a dampening factor over 1000 and a very high slew rate) but treble could be a little more detailed and it could have more transparency. When I had the 600R in my system, it gave the impression of much more space between between instruments and the sound stage seemed like it extended out beyond the walls of my room. Even compressed recordings like Fleetwood Mac Rumors sounded uncompressed. I am looking for more of that with the X250. I also expect it to be effortless like my A21 which was 400wpc and had 60 peak amps which is 40 amps more than the Pass. The A21 actually specs out better than the Pass but specs don't always equal good sound. However, I do find it interesting that the A21 has 3 times the peak current of the X250 and my Maggies love current and power. I know that I won't be disappointed by the Pass amp.
  • 10-12-2013, 03:01 AM
    thekid
    Dire Straits -Brother in Arms
    Just a very well engineered CD that allows you evaluate just about all ranges your gear can produce.
  • 10-13-2013, 12:26 AM
    huameitang
    be a little more subtle for you but you might be surprised at the difference as well.http://www.ximi.us/usa/images/28.gif
  • 11-29-2013, 04:52 AM
    peterBj
    1 Attachment(s)
    music for new equipment
    :smile5:I recommend these recordings from ECM,Sound Liaison and Reference Recordings.
    They are all brand new recordings available as Hi Rez downloads.
    Since they are all new, they have been recorded with the latest state of the art equipment and the sound quality proves that point.
    All three albums have been nominated for best album 2013 in various magazines,online magazines and forums,and are the best ''sounding'' in my collection.
    http://www.allaboutjazz.com/coverart..._somewhere.jpg
    Home - Keith Jarrett / Gary Peacock / Jack DeJohnette | Somewhere | ECM 2200 - ECM Records
    Keith Jarrett;Somewhere',
    The Neue Zürcher Zeitung headlined its review of the show “Kontrollierte Ekstase” – controlled ecstasy
    http://www.soundliaison.com/images/A...ilan%20300.png
    Carmen Gomes Inc.- SSS no.1
    Carmen Gomes Inc.;Thousand Shades of Blue
    Sound Liaison, producing recordings available only in 24-bit/96kHz downloads that mirror the master recording. And man, are they ever sweet. I've seldom heard recordings that were so successful in both performance and sound aspects.-Rad Bennett,SoundStage!
    http://referencerecordings.com/image...%20Cover_s.jpg
    Reference Recordings - RR-130 Detail
    Doug Macleod;There's a time
    ..impeccable playing, impassioned singing, and his engaging personality shines forth in a live setting. It all makes for a very enjoyable if very traditional experience." —Robert Baird, Stereophile
  • 11-29-2013, 05:18 AM
    blackraven
    I will have to check those out. I have a couple of ECM recordings and they are excellent quality, I have Doug Macleod on an XRCD
  • 11-29-2013, 11:40 AM
    harley .guy07
    do you have Norah Jones come away with me. I have that album on High res download 24/196 and it sounds really good for testing to midrange quality and how well female vocals are presented with your system. I do not know how good the cd or sacd sounds since mine is a download.
  • 12-20-2013, 09:57 AM
    Bolle
    Great choice of recordings.The Sound Liaison recordings(Carmen Gomes)are also my go to show of files.
    Actually all the recordings from that label,4 in total,are awesome.
  • 12-21-2013, 10:05 AM
    hifitommy
    i will certainly second the RR discs, i have a few such as DAFOS by mickey hart on LP. great music and performance by mickey hart et al and this disc has a real torture track. there is a spot when the 'beast' (a whole circular rack of percussion instruments) falls to the floor.
    suffice it to say i was trying to listen too loud and when the beast falls, all four of the fuses in my adcom 555II vaporized. quite a transient event.
    Amazon.com: Dafos: Music
    as you see in this amazon ad, the LP goes for $150 these days. the cd is considerably less, even on ebay.
  • 01-05-2014, 05:19 PM
    Sir Terrence the Terrible
    Attachment 9494
    You my friend have excellent taste in music.
  • 01-05-2014, 06:26 PM
    Feanor
    Thanks for that, Sir T :22:
  • 02-24-2014, 04:46 PM
    Maudi
    1 Attachment(s)
    After Silence
    I just downloaded these 2 free hi-rez downloads from the Sound Liaison label.http://www.soundliaison.com/all-our-products/88-free-tracks
    And being very impressed bought both albums.
    The After Silence album is with the remarkable trumpet virtuoso Andre Heuvelman,
    loads of technique but also able to convey true heartfelt emotion, and what a beautiful choice of repertoire, well know tunes interchanging with lovely new work and improvisations.
    I am very impressed with the Sound Quality as well, clarity and warmth, space and depth.
    http://www.soundliaison.com/images/A...hadow%20v2.png
  • 04-04-2014, 06:14 AM
    Bolle
    25% sale on full album downloads
    They are having a sale this month, 25% of full album downloads. That is 15€,or 20$, for a full Studio Master 24/96 Wav file.
    They even have a flac file now for the Carmen Gomes album going for 12 €,or 15$.
    These downloads are highly recommended. I find them the best sounding on the market.
    This is from the SoundStage review:
    Go to the Sound Liaison site, listen to a few samples, download an album, and see if you don't agree that this intimate effort is one of the best and best-sounding jazz vocal albums to come along in many a day. By the way, the small audience applauds enthusiastically enough after the last chords of a song die away, but the attendees never interrupt or make themselves known while a song is going on. No doubt they were completely mesmerized into silence, as was I.
    Be sure to listen to: On "Dock of the Bay," Gomes creates a languid, bluesy version that is a little bit reminiscent of Bobbie Gentry while still coming across as quite original. It'll cast a spell over you.
    . . . Rad Bennett
    http://www.soundliaison.com/images/A...0_200%20v6.pnghttp://www.soundliaison.com/images/A...hadow%20v2.jpghttp://www.soundliaison.com/images/A...0_200%20v6.png
  • 07-03-2014, 09:53 AM
    Kaudi
    https://www.youtube.com/watch?v=6L7PdCueEpE
  • 07-24-2014, 04:41 AM
    Maudi
    Mahler
    This one is well recorded and played, and I actually prefer this chamber music version to the symphony version.
    Linn Records - Mahler: Symphonie No. 4
    http://www.linnrecords.com/img/album/larger/ckd-438.jpg
    Historical performance pioneer, Trevor Pinnock, conducts the Royal Academy of Music Soloists Ensemble in revealing chamber arrangements of Mahler's most frequently performed symphony and Debussy's Prelude a l'apres-midi d'un faune, on its debut recording for Linn.
  • 07-24-2014, 07:44 AM
    Feanor
    I have heard otherd refer favorably to this chamber orchestra version of Mahler's 4th symphony. I'm not sure how well Gustav Mahler would have liked the idea of a chamber version, but I know I would like to hear it.
  • 07-25-2014, 01:36 PM
    Maudi
    here is a bit of a review from the Guardian;
    The Verein für Musikalische Privataufführungen (the Society for Private Music Performances) was founded by Arnold Schoenberg and Alban Berg in 1918, to provide a forum for contemporary music in postwar Vienna at a time when mainstream concerts were becoming ever more reactionary. Attendance at the society's concerts was by subscription only; critics were banned, applause was prohibited and no programmes were published in advance. Up to the end of 1921, when the economic crisis in Austria forced it to close, more than 100 concerts were given. The repertoire was by no means confined to the Second Viennese School and its supporters, but also included music by Reger, Strauss, Mahler, Debussy, Ravel, Stravinsky and Bartók. Large-scale orchestral works were regularly performed in specially commissioned arrangements that were usually made under Schoenberg's strict supervision. Some of them were for one or two pianos, but others used an instrumental ensemble in which a piano and a harmonium supplied any missing harmonies or details.
    full review here;Mahler: Symphony No 4 (arr. Stein); Debussy: Prélude à l'Après-Midi (arr. Sachs) ? review | Music | The Guardian
  • 07-25-2014, 01:46 PM
    Feanor
    Thank you. That's very interesting.
  • 07-25-2014, 05:17 PM
    RoyY51
    I think I have the "little bit of country" that you might be looking for. The now-defunct "Nickle Creek" have made a total of four albums, and the first two (IMHO) are reference quality spins. Produced by Alison Krauss, this trio featured Sean and Sara Watkins, both award-winning instrumentalists, and the very young Chris Thile, Mandolin Player Extraordinaire. Krauss' decision to eschew the usual studio effects and let this acoustic trio stick to their unadorned roots (they had been performing together since their early teens) was a wise one. The simply-miked tracks let their musicianship and beautiful harmonies sail!
  • 07-28-2014, 03:48 PM
    Maudi
