Do you have only two speakers?
The reason I ask is that they are not your common HT speakers. If so, then you might want to consider two channel units instead of these multi-channel HT units.
BTW, I have no complaints about my Denon 2802 but, as the other guy said, either should please.
Just for clarification...
Originally Posted by johnli08540
I would like to buy a receiver to replace my old one. Somebody could give me a suggest which one is better for classic music:
Denon AVR 3805
Onkyo TX SR702.
I have Bose 701speakers
Thank you in advance for your helps.
...why HT models to listen to classical music? Both mfrs. have simple stereo rec's and unfortunately the Onkyo model you've listed doesn't seem to be in their current line-up so a direct comparison, while not impossible, will require some investigation.
Denon and Onkyo make decent stuff so either supplier would be a good choice, it really depends on the "bells and whistles" you require and your budget. Yamaha gear is routinely given a thumbs up by some, as is HK.
jimHJJ(...good luck...)
