Power requirements and whats available
Hey all,
I've moved recently and in my new place built in the early 50's I have very limited outlets, and a very slim chance of modifying or adding anything electrically....
My questions are:
1. Plugging an AMP (B&K REF 200.2) and Reciever (Denon 3803) , and an 8" Sub into the same outlet. How bad is that? There is a chance to run an extension cord about 10 feet and connecting one seperately say maybe the amp. But then all my input devices would be running on the same outlet as one of the others. But then I do have some quite nice power conditioners that may make that a non issue.
2. OK I hear about alot of people putting in dedicated 20Amp lines for their gear.
Is it enough if a couple of the outlets are on the same breaker and upgrading the breaker from a 15 Amp to a 20 Amp. Of course the wiring would have to be up to speed at least 12 Guage I would think, maybe 10. Would this give me the same 20 amp availability? Of course without the dedicated line to prossibly reduce any noise (which is what the power/line conditioners are for). Should I think of this as an option? easy cheap, more available current and amps???
If you all can provide any support it would be very much appreciated.
I'm Really curious about the questions above,
Thanks
Stuart
