Power conditioner question,Help..
I purchased a new ART Power conditioner that has 8 outlets on the back,my question is what are the most important item's in a HT setup that should be plugged into it?I have alot more than 8 components.My HT component's consist's of> Reciever,Power Amp,TV,DVD,2 Tape decks,MD Deck,2 VCR's,Digital DVR Cable Box,and CD Player.Which out of these unit's should be connected?Thanks for any help..Keith.
I would also read the manual....
Plugging 8 components into a unit that has only one power cord might cause problems. You may overload the unit if you plug the receiver and power amps into it. Even if that doesn't happen you could get a voltage sag during high usage. Sticking with only source components makes good sense from this angle.
