• 02-20-2005, 02:29 PM
    DanGinCT
    Please help w/Onkyo TX DS 595 Problem
    Hello All,
    looking for help diagnosing a problem with my Onkyo TX ds 595. I have my television hooked up to the "video 2" jacks and my CD player hooked up to the CD jacks. All my equipment is in my living room and I have two small bookshelf speakers in my adjacent bedroom hooked up to the receivers B Speaker jacks. If I set the selector to CD and listen to a CD through the B Speaker's I can also hear what's being played on television in the living room through the B speakers. The sound is not very loud however it can be heard under any music that's being played on the CD player. If I stop or pause the player the music TV can be heard clearly. I'm guessing this isn't working as designed? Any help w/this is greatly appreciated.
  • 02-20-2005, 03:29 PM
    paul_pci
    Originally Posted by DanGinCT
    Hello All,
    How exactly is the TV connected? Do you have analog cables running from the TV's "audio out" to the receiver's Video 2? Is there a cable/satellite box involved or just RF coming from the wall? I guess the first question is: have you turned every thing off, unplugged both the tv and CD and plugged it all back in again? Next, have you tried using a digital connection for the CD player instead of the analog L/R?
  • 03-12-2005, 10:54 AM
    Audioman00
    maybe you have this going on....
    check to make sure you have the video 2 imputs from the tv connected to the VIDEO 2 IN jacks on the back of the receiver, I have heard of this happening when you acidently plug the jacks into the rec out section instead of the IN side. hope this helps :>
