• 03-28-2006, 04:59 PM
    kingcu
    Please help with cd/dvd suggestions for my first major upgrade
    Hello everyone,
    I just made a decision to upgrade to the real "hi-fi" system recently (I've been using some "mid-fi" system before). I've decided on the speakers/amp/preamp and am now shopping for a cd/dvd player (I will probably do half music and half movie.)
    The components that I already had are:
    B&W 802
    Meridian 568.1
    Classe CA-300
    I am looking at the following cd/dvd players right now (these are the only ones that I know of):
    Rotel RDV-1080
    Marantz DV-8400/9500
    I am looking for a good condition used one under $1000 as I think a good used one is most cost-effective.
    Any advice is appreciated!
    Thanks,
    Tong
  • 03-28-2006, 06:04 PM
    paul_pci
    My understanding is that Arcam and MusicHall make among the best high end CD players. I've only heard Arcam while auditioning speakers at audio shops,so I can't get real specific about it. But check 'em out and see what you think.
  • 03-29-2006, 03:15 AM
    accastil
    you can also add musical fidelity as one of your options for the CDP :)
  • 03-29-2006, 08:24 AM
    kingcu
    Thanks for all the information. Since I need a cd/dvd combo, the musical fidelity will not work for me, since it looks like they only make cd players.
    I am currently looking at Arcam's DV 78, which falls into my price range and from the reviews I read online seems to have both a good cd playback and good video quality. Can someone tell me how can I find a arcam dealer in Philadelphia area? I checked their website (they are actually a British company), but it has only one US dealer in Indiana listed on their website. Thanks.
  • 03-29-2006, 01:38 PM
    paul_pci
    Actually, what you found, and it is a bit confusing, is the distributor not the dealer. Go to the distributor's page and it has a "dealer locater" link and you can put in your zip. Since I don't know the zip for your neighborhood, I'll just give you the link to the distributors page:
    http://www.audiophilesystems.com/
    Good luck.
