Need help with Car Amplifier
Hey, I have an Eclipse 36401 Car amp that won't power up. When I supply it with the constant 12V, switched 12V off the ignition, and GND, nothing happens. After checkin all the connections, I found that when the wires are connected, the constant 12V off the battery is reading only ~9V. I'm assuming something is screwed up internally, but I have no idea what or how to check it. None of the components are charred or anything like that, so I'm stuck. If anyone has (or can get a schematic) or has any ideas I might be able to use to fix this, that would be great. Thanks in advance
