Results 1 to 3 of 3
    Jan 1970
    Leander, Texas
    Floorstander Question..........
    I just bought a used set of Polk RTi150's. My question is: Is there an optimal distance these should be placed from the wall behind them?
    Thank you,
    Jason
    www.cajun-oil.com
    JSE
    JSE is offline
    Feb 2003
    Denial
    Quote Originally Posted by Cumminspuller
    Thank you,
    Jason
    I think these had a down firing port if I remember right. If that's the case, they would probably not be as sensitive to rear wall distance as say a rear ported design. However, every room is different and it will really come down to just experimenting with placement and hearing for yourself what works best. I would probably start about 18 to 24 inches out and work out from there if needed. I would also keep in mind any side walls or cabintery near the speakers since they are down firing.
    JSE
    Suspended topspeed's Avatar
    California
    In addition to JSE's good advice, also make sure the speaker isn't equidistant from the back and side walls. One or two issues ago, TAS had a bunch of articles regarding room interaction and honestly, it was one the best issues they've put out IMO. You might try to get your hands on a copy (library?) and give it a read. It was very enlightening without being overly techie.
  1. Exactly what did I buy? (Paradigm question)
    By slmcdonald7 in forum Speakers
    Last Post: 09-17-2004, 08:50 PM
  2. Stupid turntable question...manual control.
    By N. Abstentia in forum Analog Room
    Last Post: 08-24-2004, 08:30 AM
  3. Replies: 12
    Last Post: 07-05-2004, 03:14 PM
  4. Impedance question
    By lumiere in forum Speakers
    Last Post: 06-10-2004, 12:57 PM
  5. A real newbie question....Please help
    By mjnoles1 in forum Home Theater/Video
    Last Post: 06-06-2004, 08:27 PM
