Line Noise and Picture Distortion
Hi all,
I have a line noise problem, but I didn't find any other posts here that described this exact scenario. I have a Yamaha HTR 5460 receiver hooked up to a small 19" TV that servers as the monitor output. I also have a VCR hooked up to the receiver with normal RCA cables. Finally, I hook my laptop up to the receiver for audio (that connection splits the headphone line into dual RCA). Pretty typical setup I'd say.
The problem I have is when I hook up the cable TV line either to my TV or to the VCR, and have my laptop audio hooked up at the same time. When I do that, I get serious line noise and a distorted picture on the TV. When I don't have the laptop hooked up for audio, everything is fine except for a little static noise at higher volume (but I think that's been there for a while anyways, and it's probably due to a bad speaker connection).
Now the only thing I've been able to figure out is that I only get the extreme line noise/picture distortion when the laptop is plugged into the power outlet. When I unhook the laptop power line (still leaving the audio hooked up to the receiver), the noise goes away and there's no more distortion on the screen.
I thought this might be a polarity issue but perhaps it's a grounding issue as well since the problem goes away when I unplug the laptop from the wall power outlet. I've tried hooking up the laptop, TV, receiver, VCR, etc. to different outlets, but that didn't seem to change anything. I've also switched the inputs for all my components at least twice, so I don't think that's an issue.
Anyone have any advice on how to fix this or work around it? Thanks.
