Results 1 to 3 of 3
    May 2006
    Milano, Italia
    Exclamation Damaging headphones
    Hello,
    I plan to buy a high quality AKG headphones but I have a problem with mine amplifier. The Phone Out has a strange 'bzzz' noise and I'm worried if it could damage the headphones. It's mostly strong at Low and Very High volume, and attenuate itself at Medium volume.
    Thanks.
    P.S.: I cannot buy a new amplifier (it's a good quality Aeron A2, at least on a SQ standpoint, but suffer a bit from Quality Control). I have to renounce to the new AKG for now?
    Sgt. At Arms Worf101's Avatar
    Troy, New York
    Sounds like a short...
    Headphone or 3/4 jacks are notorious for bending inside and/or shorting out after extensive use. If it's shot, they're not hard to replace and should cost little to fix. I don't know how old your receiver is but if it's old you may just want to upgrade anyway.
    Da Worfster
    May 2006
    Milano, Italia
    Thanks Worf, I'm thinking in changing the amplifier.
