Results 1 to 14 of 14
    Nov 2009
    only problem is I couldn't see an easy way to get to those to check the joint, or for that matter to fix them. I didn't have a real good look though, maybe there's an easy way.
    Margate, Florida
    You can certainly try fooling with the pre-amp/power amp connections. True that most of these receivers etc for the average joe are hard to work with particulaly to find a cold solder joint. I wish they were built like Dynaco equipment which was easier to get at.
    This is why they have dumpsters.
    IF YOU ARE enjoying this "project" good for you. But I doubt you will be successful.
    SOME STUFF is just old , and the only "fix" is a well placed Nato round.
    HAVE FUN , ANYWAY.
