Kenwood DP-R893 minor issue
Picked up my first CD player. Kenwood 5 disc changer for $20. Definitely blown away with the quality compared to my laptops disc drive. Well, I haven't had another player to compare sound production quality, but the disc reading quality is certainly far better. CD's that skipped or were fuzzy on my laptop are nice and clear on the kenwood.
Anyway, minor problem. Quite consistently, when I hit play, the thing just sits there and nothing happens. If I give the disc drive a nice good shake, I can hear the player drop the disc in and begin to spin and play. Once this happens, it plays fine and will go back and forth between all the cd's in there no problem. So it works, and I can consistently get it to work, but obviously it's not ideal to shake it every time i want to play it.
Anyone know what might be causing this? Something loose? Something in the way? Is it easy to fix, or should I just be happy I got a mostly working player for $20?
