Hi, I too karaoke on my HT system and really enjoy it even though I am nowhere near star search capability. Do you have a standard DVD player? If so then it is simply a matter of getting a microphone mixer. Shure makes an excellent one but there are many more on the market. You will have to use the L/R RCA jacks (ie analog) to hook it up. All you do is connect the L/R output of your DVD to the mixer and then run the L/R from the the mixer to your receiver/amp. Here is a model from shure (they can be found on ebay for about 1/2 the price).
Shure has many more mixers too (including digital), but the price increases with more capability and inputs.
05-23-2004, 02:09 PM
sharow
And could u suggest amp and speakers for the Karaok system ?
Thank you
05-23-2004, 05:19 PM
poneal
Sure
I'm not sure what you are after but I will post assuming that this is not for home theater use. A good studio quality amp that I can recommend and also has high customer acceptance is the alesis RA300. It is a dual channel amp with separate volume controls for each channel. Here is a link:
Here are some very good monitors (speakers) from parts express. I have dealt with parts express and they are a very good company. They do require assembly and basic soldering skills (and I mean basic) but you can't find a better monitor for these prices. Here is a link.
By the way, that amp can be used with anything and is a good amp so you may wish to keep it around for a long while. If you need anymore help just post again. I check periodically.
05-23-2004, 07:42 PM
sharow
Thany you very much~~~~
That is exactly what i want ~~
