How to connect Marantz receiver + Marantz Amp + Equalizer
:confused:
Hello
This is my first post to this forum and I sincerely hope to find my answer here from you Audio experts. here is:
I have:
Marantz Receiver 2226b (w/ pre-out , main-in jacks also tape monitor)
Marantz Console Amp 1060 (w/ pre-out , main-in jacks also tape monitor)
Marantz 5420 Tape Deck
Marantz 5010b Tape Deck
Marantz LV520 LD CD Player
Numark Turntable
Tarkus (brazilian) Semi-Professional Equalizer (able to connect 2 tape decks)
My question is: How to connect those equip in order to get the best sound ?
You can reach me at : fabiog@unisys.com.br
Aahhh....an integrated amp, eh...
...and some older gear...I'll hazard a guess there are no manuals to look at...
Anyway, as I earlier suggested, those connections will get you up and running, now for the integrated...not much diff power-wise between the receiver and the integrated(26Wpc vs. 30)...in a stereo system it's not really required, however if you to plan on using it for rear channels or another room, you could feed the remaining "tape out" from the receiver to the "aux" of the integrated...that will give you volume and tone controls in a "rear channel"/ "zone two" set-up...if you plan to bi-amp your front speakers, you can by-pass the vol and tone controls and wire directly to the integrated's "power-in" jacks...many possible connections, it all depends on your plans...you could even build a second, independent system around it...all depends...
jimHJJ(...good luck...)
