Check out DBX eq's, and Alesis. Rane and audiocontrol are out of that price range. Alesis has more bang for the buck. Its reasonalbly priced, extremely low distortion figures, constant Q, quite a few presets(its a digital eq), and VERY low noise. The DBX is equal in quality, a little cheaper, a touch noiser, but plenty of flexibility.
Uhm, Rane, DBX and Alesis are hardly designed for a home system.
Rane, more expensive than DBX?? Alesis less noisy than DBX?? hmmmm.....
Alesis has had quality issues in the past with their EQs.
You wouldn't be an Alesis biggot would you????
-Bruce
