Hi, planning an upgrade and need some advice =)
Warning, newbie thread ahead. I tried to read up on as much as I could but there's so much stuff out there it overwhelms me =P
I've been a developing audio enthusiast for some time now but I still know relatively little about how it all works. I had a basic Mission 5.1 (bookshelf) setup with a Sony receiver a few years ago that must've cost around 300 quid max. Since then I moved to Hong Kong and sold that system and I've only had my Shure e3c earphones for comfort until recently, when I bought the fantastic Denon AH-D5000 headphones, which I'm using with an X-Fi Platinum soundcard. To me they sound amazing but I'm longing for a loudspeaker setup again so I can enjoy my rock music =)
My budget is relatively low, around 1300. The upside is that there is no VAT in HK, not even 1%, and the audio selection is phenomenal - I have no idea where to start, which is why I'm starting this thread.
I'm happy with the digital outputs of my PC in terms of film and music, I store all music in lossless format and have the necessary programs to use it as a bit-matched transport, which is adequate for my needs. I also play a lot of games and I'm looking at having the PC (which is very quiet =P) near my setup because I know how expensive cabling can get. I know this is a big nono for a lot of you but HK accommodation is expensive and small; I don't have a living room and a listening room, everything happens in one place here, I'm lucky I have a bathroom ;D
I need receiver (audio + video if possible), speakers, cables. I would like a decent 5.1 or a better than average 2.1, that is if I even need a subwoofer? I always find I keep subwoofer volume very low because it becomes overpowering. Are there good 5.1 sets in my price range?
I have no idea how to correctly choose a receiver that matches my speakers and then what cables to get the most out of it. Any cable companies I should be aware of for spdif and analog out for my soundcard connections? Are there new speaker technologies I need to look for? Is 96 khz relevant? Any receivers in this range with good DACs?
Basically I'm a blank slate, I just want a tightly matched system to give me a fresh start, any opinions are welcome, thanks!
