Results 1 to 11 of 11
    Dec 2009
    How to play USB on a receiver?
    I just got a USB stick loaded with songs. I inserted it in my Anthem receiver, but there is no sound. How do I get the USB to play the songs? Thank you.
    Suspended markw's Avatar
    I don't know, but the first place I'd look is at the owners manual for your particular receiver.
    Quote Originally Posted by ken88 View Post
    Is it an MRX model Anthem receiver you have?
    Check the manual that came with it or download from HERE. See Section 4.3.2, Multimedia / USB Mass Storage Devices, page 32.
    Aren't you a big boy? Can't you do this for yourself?
    Dec 2009
    It's the Anthem MRX I have. I read the manual but there is not enough info to explain how to play the music. The Multimedia section on USB did not explain it well enough how to play the music once you connected the USB to the port. Any help would be much appreciated from anyone. Thanks.
    You could try a different flash drive. Make sure it's formatted with a file system the MRX handles; load some music files of type (or types) the MRX can handle, e.g. MP3. Note as the manual says that for first use the MRX will take some time index the files. The USB flash drive you were originally trying might have some "junk", i.e. files or directories, that are unacceptable types and which are confusing the receiver.
    Are you seeing the USB screen as shown on page 33 of the manual, (the version on the website)? Unfortunately there is the possibility that the receiver itself isn't working properly.
    Philadelphia, PA
    If you're using a flash drive from a MAC that could be the problem. A lot of gear with a USB input doesn't recognize a flash drive unless it's formatted to FAT32.
    Dec 2009
    I can't see any USB screen as shown on page 33 of the manual!! What do I have to do to see the screen on TV? Thanks a lot Feanor.
    Sorry, ken88. I can't diagnose the problem any further from here. Apparently the MRX isn't recognizing the USB drive, but why that is I can't say.
    Are you allowing the MRX to index the drive? The manual says this can take time -- I can imagine that this could take several minutes. I would guess that this process includes reading the files and extracting info such as the album name, etc., which aren't part of the file name but are referenced on the screen on page 33.
    Perhaps you could ask the dealer where you bought your receiver.
    Dec 2009
    By the way, how do you set the MRX so that you can see the controls on TV screen? Right now, the controls are displayed on the MRX panel. Many thanks.
    It's time to talk to to Anthem Tech Support
    Anthem Electronics Inc.
    205 Annagem Blvd.
    Mississauga, ON L5T 2V1
    Canada
    General Numbers:
    Phone: (905) 564-1994
    Fax: (905) 696-9479
    Customer Service:
    Phone: (905) 362-0958
    Fax: (905) 696-9479
    Oct 2005
    Have you tried a different USB drive, thumb or portable?
