Help needed, Onkyo 801 vs. Yamaha rxv1400,
Have narrowed my choice between the 2 av receivers, plan to match it with mission speakers on a 26 sq.m. room, thanks in advance!! :( :) :confused: :cool:
Yamaha makes good receivers
I've been using Yamaha receivers for the past 8 years. Although both the Yamaha and the Onkyo have all the Dolby Digial EX, THX Select, DTS ES, etc.. etc.. I'd definitely go for the Yamaha. IMHO, it has a much stronger amplifier section, not just in quantity, but primarily in terms of quality. Also, I find the room calibration feature pretty useful. Hope that helps. Good luck!
