Help with MP3 player selection
My wife wants a new MP3 player and she left the decision up to me on which one to buy. My wife wants to use it while she runs, and I want to add a input to my car! I am only looking for a flashdrive player not a mini harddrive so the ipod mini is out of the question. The flash players can take the constant movement of exercise and running.
I have narrowed it down to 2 choices, (I think)
The Jetaudio/Cowon America i2 And the Samsung Yepp YP-t7
Both of these players got the highest scores on cnet.com reviews and they are similar in price. Anyone have either one of these and can make a recommendation?
Thanks
Matt
there are a couple directions you can go..
I wouldn't be so quick do discount hard drive players. I've been using the Rio Carbon for over six months on an almost daily basis. Unlike it's predecessor the Rio Nitrus, it uses a Seagate brand hard drive. It's been dropped hard on concrete and ceramic tile, been rained on and shaken and stirred. It still works flawlessly. It's Audible compatible, has hard bookmarking, almost 5 GB's os storage, is a UMS storage device (pc and mac), at least 14 hours of playback and has a sublime form factor. If you're set on a solid state player however, I wouldn't apply too much research or logic in your choice of players. Get her an iPod Shuffle and forget about it. Unless you're wife has geek tendencies, she'll appreciate the Shuffle on several levels.
