Results 1 to 2 of 2
Thread: D/A converter
    Forum Regular vr6ofpain's Avatar
    Jul 2004
    Town, State
    D/A converter
    Is there such thing as an affordable outboard D/A converter? I am starting to think that considering I use my computer for both my cd player and mp3 player, I should use it's digital out, and run it into a decent D/A converter, then into my preamp.
    I figure this way I will bypass whatever garbage D/A is in my soundcard.
    Anyone know of some good D/A converters, new or used, for less than $300?
    Lower AL
    Quote Originally Posted by vr6ofpain
    I've read some things about the item below. Apparently it has to be modified to perform in a home system, but I'm not sure. I wish I could tell you more about it, but maybe you can find compatibilty info better than I can. It's the ART DI/O. The ad is from musician's friend.
    View all ART products
    Warranty Information
    DI/O Sample Rate Converter
    Product #180580
    Zoomable Picture
    Show Larger Photo
    View our Return Policy
    Features: 8.00
    Quality: 8.00
    Value: 10.00
    Overall: 8.00
    (Based on 1 rating)
    Rate This Product
    This product is eligible for FREE SHIPPING! Click for details
    SAVE $79.01 (39%) When You Buy Today!
    List: $199.00
    Our Price: $159.00
    Sale Price: $119.99 Guaranteed Lowest Price!
    Platinum
    Payments: As Low As $15/mo
    Availability: In Stock
    Quantity:
    (You can always remove it from your cart.)
    Recommended Accessories:
    Click the checkboxes, then click "Add To Cart"
    Hosa Double-Shielded Coax Gold-Plated RCAs 6.6 Foot $9.99
    Horizon Dual RCA-QTR Cable 6 Foot $14.99
    Horizon Dual RCA-RCA Cable 6 Foot $14.99
    24-bit, 96kHz interfacing for wherever your system needs it.
    This little device can be the home or project studio's best friend. It allows you to maintain sound quality when using "classic" analog components and improves any sound card's dynamic range by moving the A/D-D/A out of the PC. You can improve the performance of DAT machines, MiniDisc recorders, and DVD players; and use it to upgrade the performance of existing digital I/O products. Or reduce system noise on any computer-based audio workstation. Lets you add 2 high-performance channels to your multichannel interface. Or make samples warmer, softer, and more musical. Conversion: 24-bit, 96kHz, 128x oversampling. Sample rate: 44.1, 48, 88.2, or 96kHz switch selectable. Digital interface: S/PDIF coaxial, in and out, RCA jacks. External sync range: 22kHz -100kHz. 3-year warranty.
  1. Voltage converter
    By freediver in forum Digital Domain & Computer Audio
    Last Post: 08-16-2004, 07:46 PM
  2. Digital converter box connections
    By SteveH in forum Home Theater/Video
    Last Post: 03-12-2004, 10:09 PM
  3. Converter question?
    By Sue in forum Cables
    Last Post: 02-27-2004, 08:02 AM
  4. Do we really need 3 yr old CDs remastered?
    By Davey in forum Rave Recordings
    Last Post: 02-06-2004, 08:54 PM
  5. Converting Optical to RCA Type Digital
    By gburglax in forum Home Theater/Video
    Last Post: 01-07-2004, 06:39 PM
