Help with fuses
Is there a dfference between slow blow and microwave fuses can a microwave fuse be used instead of a slow blow?
If you are trying to use a better fuse try these
http://www.vhaudio.com/hifi-tuning.html
but back to your question as long as they have the same electrical rating I would think it would be okay.
