Help fixing my HK PM640 Vxi Integrated Amp Please
Hello folks. I am new to this forum so please excuse my ignorance to any unkown help request protocols.
Here's my problem that I'd like advice on how to fix. I have a Harman Kardon PM640 Vxi High Voltage High Current Intergrated Amplifier which has a barely audible left channel. Makes no difference if using A or B or Both speaker selector settings or any of the inputs (CD, Tuner, etc.). I have to turn it up about 60% of max to get any sound from the left speaker at all. Which normally I would never do given the power of an HK amp. I am running Ohm Walsh Cam - 32 speakers and the amp is set to 8 Ohm mode (has a 4/8 ohm setting option). I have tried both the 4 & 8 ohm speaker settings & the problem still exists.
I have openned up the chasis to look for blown fuses, etc. but cannot see anything that looks broken. I also have no idea what I am looking at. I have a local repair shop that could probably fix it for an arm & a leg, so I thought I would ask you audiophiles first.
Thanks for any advice! - Scott in Jersey
Update on HK pm640 Vxi Int Amp Testing
Thanks for the suggestion Jeskibuff. I swapped the speaker leads left to right & right to left and had the same problem just from the right side (when hooked up to the left speaker lead on the amp). I have tried both cheap speaker wire (~22 gauge) and my high end 12 gauge, same result. I have also tried other speakers (DCM TF500s) and had the result. I have also tested the Sony CD player, Onkyo Integra Tuner & Apature HD AV interconnects using a old Sony Integrated Amp and everything worked fine from both channels.
So I am pretty certain the problem lies within the HK Intergrated Amp left channel. Any further suggestions would be great appreciated. Thanks again!
