HDTV Audio Switcher?
I'm new and a novice.
I need a switcher to go back & forth betw. my Cinema speakers and my headphones. (all RCA inputs & outputs).
I have HD TV with HDMI Audio and I do not want to lose any signal.
I see many of the following types of switchers but I am not sure of the differences between: Component Inputs, Stereo Analog Audio Inputs, Stereo Coaxial Stereo Inputs, Composite, Toslink optical digital audio, etc.
Which would work best for HD TV / HDMI Speakers and headphones?
Thanks.
Bruce
If you are using your TV's speakers then its simple, just use the headphone jack of your set, or get two rca plugs connected to a phono plug and plug the rcas into the speaker outs of your tv
RE: Audio Switchers
Both my set of speakers as well as my headphones use a set of RCA jacks - and I have only one input for the RCA jacks so I need a switcher. But I am not sure of the differences between switchers that have differnet kinds of audio inputs such as: Component Inputs, Stereo Analog Audio Inputs, Stereo Coaxial Stereo Inputs, Composite, Toslink optical digital audio, etc.
Which would work best for BOSE cinemate speakers and a pair of wireless headphones on HDTV for the best sound with least signal loss? Component Inputs? Stereo Analog Inputs? Stereo Coaxial Inputs? Composite?
Thanks.
I've never come across a set of headphones that have RCA jacks at the end of the cable. I suspect they're left and right and they're male plugs, is that correct? I and probably a lot of others here have little to no experience with Bose cinemate speakers, so you may not get much help in that regard. Is there a receiver in the mix? Is this a Home Theater in a Box type of arrangement? What brand and model are your headphones?
I suspect they're left and right and they're male plugs - that is CORRECT.
The WIRELESS headphones sit on a base which has L&R RCA jacks.
http://www.amazon.com/Sony-MDR-RF960.../dp/B0001YFZ46
The BOSE Cinemate speakers have a small receiver that also have L&R RCA jacks that plug into the SAME 2 RCA audio inputs in the TV.
I need to switch back & forth.
I know it just requires a simple A-B switch, but I am looking for one that has high quality connections and switches so as to try and not lose any of the audio quality.
Thanks.
Any AB switcher will do. Niles Audio makes a lot of high quality switchers for various uses.
www.nilesaudio.com
I use a niles switcher for switching between 2 power amps and and 1 pair of speakers.
