Furman Elite i Series 15Pfi thoughts?
Hi,
I will probably be purchasing a power conditioner in the near future and I was wondering if anyone had some thoughts on the Furman Elite i Series 15 Pfi.
I am wondering if the Furman mentioned is a good unit or whether I should spend more on something better. I don't want to spend a ton of money on a conditioner but if I should be spending a bit more for something that would be much better then I would do that eventually. As an example I have been eyeing up the PS Audio power plant premier but they cost over $1500. Therefore, if there is no significant performance upgrade I don't want to have to spend that extra money. I don't have any experience with conditioners so any helpful feedback would be appreciated.
I would like to use it as part of an HT system and as part of a 2ch system. All my components are in the same room and I will be switching between the two systems.
I have an Emotiva XPA3 and Yamaha RXV1700 for amplification for HT and I have a Toshiba upconverting DVD and a Panasonic Blu-Ray for HT. Also as part of that system is my Samsung 50inch plasma and a Shaw HDTV PVR receiver.
My 2 channel system consists of an integrated tube amp and a musical fidelity xray v8 CD player.
My speakers are av123 LS6's for the fronts and Rocket RS1000's for rears and an av123
x-voce center channel. The LS6's will also be used for 2 ch.
I am currently having issues with my tube amp, as I hear a relatively loud hum that may be coming from the transformer area and it transmitts through the speakers. I am really hoping that the problem is not due to an issue with the amp, because I'd hate to have to ship it away to get fixed, as any issue may have occurred during shipping, as there was no issues with the amp before.
I have tried everything to cure the problem, like changing tubes, interconnects, speaker wires, ground loop cheater plug, plugging into an APC Back UPS ES 650, moving the amp to a different circuit and no change.
I know the Furman may not cure that issue, as I may have to send my amp in to get checked but I would like to get a conditioner anyways and if it helps with that issue it is a bonus.
Any thoughts on what would be the best bang for the buck conditioner and thoughts on how the Furman would measure up will be appreciated.
Thanks in advance for all input.
