You may have hit the nail on the head...
Originally Posted by Pat D
What source are you using? I can see feedback, strictly speaking, if you play records. Feedback requires that your player be able to pick up vibrations from the speakers and feed them back through the chain. This can happen with turntables and cartridges but not with CD players and tape decks. Moving the turntable away from the speakers usually helps.
You may, however, be describing a room resonance problem, but it's hard to say. You can calculate the approximate resonant frequencies by dividing 565 by the room dimensions in feet, but since your room is open to the rest of the house, this probably is not too useful.
I was listening to both vinyl and CD's...but mostly vinyl. I thought (but I'm not 100% sure) that it was occuring while using both sources. Having said that, my turntable is right next to my left speaker and it was only occuring in the left speaker. Plus while I was using the CD player the turntable was still turned on. I think you may be onto something.
I'll try and throw the wife and kids out next weekend as well and try moving the turntable further away from the speaker and see if it makes a difference.
Thank you for your input...
