Equalizer Help
Here are some pics of a Project one amp and receiver. I am haveing trouble hooking up the equalizer. How would i do this?
[IMG]http://img24.imageshack.us/img24/8075/ampop.jpg[/IMG]
[IMG]http://img832.imageshack.us/img832/8720/equalizer.jpg[/IMG]
Run it through your Tape 1. EQ out to MON, REC to EQ in. Then engage Tape 1 while you listen.
If you have pre amp in's, then that is were you should hook it up.
That would be my vote, too. Unity gain input with bypass.
