Element dimensions/spacing on the Winegard HD6065P FM Antenna?
Greetings guys. Question. I have a Winegard YA-1713 VHF Hi-band 100" yagi and a RS VU-190XR which i don't use and eventually wound up eating (antenna return policies swallow don't they?) and soon to be butchered/modded.(RS into the Winegard). I'm currently using the RS 15-2163 for my FM listening now, but I know Winegard nor any other antenna manufactuer would never disclose element diameter and spacing.(can you blame them?). I know that the HD6065P is very similar in size to it's cousin the 1713. I'm looking to Dremel out and trim the elements of the VU190XR and installing them on the WG. BTW i did a few keyword searches in Google under Yagi construction, 10 element FM Yagi, and a few other keywords and found a few helpful sites, but dimensions and spacing are not as detailed. Do you know of or think any yagi design software would go into further detail? I originally was going to send this message to TB, but i said what the heck. Thanks guys.
