DVD Audio newbie question
Hello,
I just bought the DVD audio version of Diana Krall's "Love Scenes". This is my first the DVD audio purchase. When listening to the DVD in Dolby D mode I noticed the sound coming from my rear surrounds sounded very low compared to the fronts and center channel. Is this how it is supposed to sound? I just assumed the levels coming from each speaker would be pretty much the same. I'm using a Panasonic DVD-RV 31 connected to an Onkyo TXD 595. My front speakers and rear surrounds our paradigm Atoms and a Paradigm center channel, I forget the model number of that. I've got all the speakers calibrated to the same levels except for the sub. Doesn't that mean that the fronts and rear's should be putting out the same level or is that just how the DVD is mixed? I do sometimes have a problem with the Onkyo where when I try to calibrate the rear speakers I don't get the pink noise tone until I adjust the level to a high level like seven or eight and then the tone slowly builds up to that level so perhaps there is a problem with my receiver? I have tried switching around the fronts and rear speakers and still have the same problem. Thing is, when I play movies (such as Saving Private Ryan or Finding Nemo) in DolbyD or DTS mode the rear channels sound fine even when their calibrated at the same level as the fronts. Thanks for any information you can provide!
Daniel
Your listening to the Dolby Digital mix
Originally Posted by DanGinCT
Hello,
Daniel
Not the DVD-Audio layer. While it will sound OK in DD, DVD-Audio is much better. I play most of my DVD-Audio disks in Hi-Rez Stereo.
