Denon DVD-Audio connection help
I had this issue when I first got my 2900. A quick fix in the menu fixed everything back up. Problem is I moved my equipment and forgot the quick fix. The deal is that the 2900 will play SACD's fine, but not DVD-A's. The light on the panel of the 2900 registers a DVD-a, but my pre/pro (Krell) reads a 24/96 signal. Also, on the monitor the option for DVD-audio is not there, just the DTS mix. Chrs gave me a fix in the settings of the 2900 that solved this, but I am just exhausted looking for it. Anyone know this fix? My Krell is set to "see" the 5.1 anolog outs (I can play SACD's fine), but the 2900 is not putting out DVD-A. Help!
