Results 1 to 2 of 2
    Denon AVR 85 as tuner
    I have used this unit as tuner for FM listening, connected to another AV amplifier. Denon AVR 85 has no speaker connected. Is this ok , or will it not affects the unit.
    Denon AVR 85>>AV amp>> speaker. Denon AVR volume control level set to -09
    Crank it up, dude! huh? hydroman's Avatar
    Jan 2007
    Chesapeake Beach MD
    Not a problem. Use the pre-amp outs. Keep the '85 volume at its lowest. If you have the a/b switch see if you can just 'half depress' one switch and the both pop up/off...
    H/K AVR635 7.1
    Denon DVD900
    AE AEGIS III Mains
    ION USB Turntable w/ Shure M97XE
    15" Titanic III Sealed Enclosure Sub
    Dayton Rackmount 1000W :O
    Denon Surrounds
    Sony Bravia KDL40S2000
