It sounds like a DAC would be a good upgrade path
Originally Posted by quad121
Hi Nightflier, My Marantz iv very good at recreating the sounds of he instruments but it does come over slightly bassy. Also i find it doesn't show how the instruments interact very well.
Then a DAC is definitely in order. But you may have to try out a few until you find one that you like. You may want to go the used route so that you can resell the ones you don't like w/o too much expense. A couple of companies I would recommend: MSB and Musical Fidelity.
