DAC volume question
I am having a problem with an older DAC from Apogee/Cello (Model DA-1000E-20). It's a higher-end unit but because Apogee has gone through several owners since it came out, they cannot service it.
The problem is that it has virtually no sound. When I mean virtually, I mean I have to turn the volume up to 80% or more to get just the faintest audio. I have tried all the different inputs, different components, different cables and I get the same result. It has two volume pots on the front, but they don't help either. Any idea what might be the problem?
Also, I don't have a manual and cannot get a copy from Apogee either. I was wondering if anyone out there had one that they could photocopy or scan for me. Thanks.
did you try whacking it real hard?
No, but it is built like a brick. Two bricks, with the power supply.
I just received an email suggesting that there may be an impedance problem because this is a profession DAC and not a commercial one. Does anyone know what that means? Does a pro DAC need different equipment?
Are you plugging the right one in? Just trying to be un-helpful. ;-)
It may only support the AES/EBU interface which indeed is different from the more common S-PDIF format. See attached link:
http://www.epanorama.net/documents/audio/spdif.html
