cinder blocks as speakers stands?
How well do they work? I am planing on getting 6 8x8x8 cinder blocks and spray painting them black. I know they will be sterdy and thats what I'm going for. Will it change the sound at all? Is they any disadvantage in using cinder blocks as speaker stands?
Man, I just had the biggest college days "flashback"
Don't ask questions like this. Guys over 45 years old immediately start havin' hippie, psychodelic flashbacks... Man did I just have a laugh reliving the student's "furniture of choice", the ever faithful cinderblock.
Da Worfster :D
Just don't be going Kung-fu on them after a few cold ones
The only bit of advice I would add from my experiences is to try stuffing a some soft material in the holes (assuming they're the common 2-hole variety).
When stacking I found it worked best to stuff towels, as was mentioned by someone else, inside the holes. Might have just been me, but we got some weird echo/resonance effect with'em. Soft material tends to insulate them, and also limit how much they can move if you, a cat, or whatever should bump them slightly.
My neighbor's got a few in his front yard you're welcome to, you'll have to move the Ford Tempo off them yourself though.
Cheers!
speaking of speaker stands
I have 2 sculpture stands that I was thinking about using. They are just laminated MDF and are pretty heavy duty but are hollow inside. I can't fill them up with anything the way they are constructed. Will this cause any problems?
