Cerwin Vega Re-30s + Technical Pro HB-1501
I have a Technical Pro HB-1501 Hybrid amp/receiver , which has 4 channels. I also have four Cerwin Vega Re30s, which, according to the labeling on the back, are rated at 4 ohms and 250watts each (standard main with tweeter, middie, and a sub).
When I had a pair of the Re30s hooked up, it sounded pretty good, but I kept blowing out speaker fuses around 50 and above dbs (according to my receiver). So in my mind, I figured that the receiver was outputting more energy than the speakers could handle at higher volumes, which is why the fuses popped. No harm to the speakers has been done, but I have burned through two pairs of fuses in the last few weeks.
So I bought two more Re30s recently ($80 bucks for a pair) and set up all four. I was hoping that now I could keep the volume lower on the receiver but still create more overall volume because of having 4 speakers (instead of 2). By keeping the receiver volume lower but having more speakers, I was hoping to play louder and not be turning the receiver power up to avoid blowing fuses. I don't really know anything about audio equipment. Is my theory flawed?
I haven't noticed much change in overall volume (because the receiver is still outputting the same amount of power?) and in fact the sound seems a little fuzzier, which might only be something I'm making up in my head. The speakers are attached by standard copper wiring, large gauge.
Very basically, will my receiver handle all four Re30s without a problem at high volumes?
Technical Pro HB-1501 Technical Specs:
1500 watts peak power
500 watts @ 2 ohms
390 watts @ 4 ohms
220 watts @ 8 ohms
Inputs: RCA (2 audio sources)
Outputs: Banana binding post (to speakers)
One RCA dedicated for record line output
Two mono RCA dedicated for subwoofer output
One RCA dedicated for preamp output
Digital fluorescent output display meter
iPod / MP3 input with cable
110-220V Switchable
