Bose speaker locations advised required! *PICS inside
Hello guys, I will be using Marantz SR-18 with Bose Acoustimass 10 5.1. As you can see my studio is very small. My couch's distance to my closet is very close. At the rear I'll just put the speakers on top instead of getting wall mount. I'll probably put my dvd player on the top tv shelf while the center speaker sit on top of the dvd player. While the reciever sits in the middle self for better ventilation.
http://i9.photobucket.com/albums/a98...s/IMG_0699.jpghttp://i9.photobucket.com/albums/a98...s/IMG_0698.jpghttp://i9.photobucket.com/albums/a98...s/IMG_0697.jpghttp://i9.photobucket.com/albums/a98...s/IMG_0696.jpghttp://i9.photobucket.com/albums/a98...s/IMG_0695.jpghttp://i9.photobucket.com/albums/a98...s/IMG_0694.jpghttp://i9.photobucket.com/albums/a98...s/IMG_0693.jpghttp://i9.photobucket.com/albums/a98...s/IMG_0692.jpghttp://i9.photobucket.com/albums/a98...s/IMG_0691.jpghttp://i9.photobucket.com/albums/a98...s/IMG_0690.jpg
Do you guys think I should go wider on the front speakers? and maybe a little bit higher?
Is it okay if I put the center speaker right under the LCD? So this leaves to a clean look.
( i'll manage to fit the DVD in the middle shelf )
Thanks for any feedback
with all due respect, look beyond Bose..
Ther are so many good 'lifestyle' home theater packages out there. Look at kef, Mirage, def tech and on and on. I'm partial to kef but there are many that can be had for less and that sound great.
