bose headphones, anygood?
Printable View
  • 02-08-2006, 06:27 PM
    Rocker82
    Im looking for some good headphones that arent insanly prices like $800. I was wondering how the Bose noise cancelling ones where and hows they sounded. do they sound good and what do u recommend? Im also looking at Sony's and possible those etymotics like companies. they look a bit expensive and i dont think in ear phone would sound as good. thanks alot and id like to hear about the bose headphones. Thanks alot
  • 02-08-2006, 07:16 PM
    drseid
    No offense intended Rocker, but you really are not going to get very far with all the "opinion" questions on headphones, speakers and the like.
    Truly the best way to find out how "good" something is, is by trying it out yourself. There most likely is a Bose store near you that will carry them, and let you try them out.
    Only you can decide if these meet your expectations...
    ---Dave
  • 02-08-2006, 09:40 PM
    paul_pci
    Check out Sennheiser headphones. They have reasonably priced models and some are noise-cancelling and others are not.
  • 02-09-2006, 09:15 AM
    The One
    Try Philips SBC HN060 Noise Canceling In-Ear Headphone - they are under $25 bucks but
    EXCELLENT performance.
    hope this helps! :p
