The best A/V receiver for around $1000
I want to buy a Home Theater system and I need your recommendation on a receiver. Also, what do you guys think of the B&W 601 S3's? Will that be a good match? Thanks.
Since you're a newb I suggest that you consider...
Ease of set up as well. All the receivers mention are good, but the Yamaha with it's automatic calibration program is something you might want to consider. If you think you're good enough to calibrate your system yourself the Denon's and Onkyo's make the process pretty painless. I know, I've set up many a HT system in the last 4 years.
Da Worfster
