Best small radio with USB/SD input?
Hey Audiophiles:
I'm looking for a small (table radio size) system that has a radio and also USB input. I'm hoping to get something that sounds decent (doesn't need its own subwoofer but has some kind of bass boost to prevent tinny sound) is one piece (not separate speakers), and is isn't expensive.
I've tried the philips DC-199B, but it has separate speakers; I've also tried the COBY 266 but I wasn't impressed with the sound or build quality. Does anybody have any suggestions? By the way, boomboxes count if they fit the criteria...
