Advice on mid-range receiver choice, please
I'm looking for a mid-range receiver to match to a set of Klipsch speakers (bookshelfs, center, surrounds - RB3II, RC3II, RS3II).
I've narrowed it down to:
Yamaha RXV-750
Yamaha RXV-1400
Denon AVR-2803
Harman Kardon AVR430
I'd like to keep it below $600 if possible, else I would probably go with the Denon AVR-2805. All of the above can be had online for under $600US.
The Klipsch's can be a bit bright, so I was looking for a receiver that can balance them with a bit of warmth. All seem capable of handling an HDTV in the future, which would be my next purchase (currently have a Sony XBR -CRT TV).
I'd appreciate any advice on which receiver you'd pick and why. Also, are there other brands/models that I should consider in the sub-$600US range?
Thanks.
